LabView 2012 Continuous Measurement and Logging (DAQmx) Project
I've been working with this example to try to build a DAQmx and Serial acquisition message handling loops, as well as another message handling loop with two analog outputs for control. This control would also be based off of information from the DAQmx acquistion loop. Is this example appropriate to do this with? I've added two additional message handling loops (Serial and the AO control loop). I worried that this example might not be the best to follow.
(2,794 Views)
I'm not sure what example you are talking about but it seems like you are wanting something like the document below.
http://www.ni.com/white-paper/14119/en
Carl W.
Applications Engineering
(2,766 Views)
Assuming I had a two MHL's, one for reading data and another writing data to disk. I would use the normal enqueue vi to pass data from the acquire loop to the logging loop, correct? I wouldn't use the message handling loop correct?
(2,760 Views)
