LabVIEW with version control
      I am using LabVIEW with version control and only want to check out the VI which I need to modify. If I changed a subVI all the VIs directly or indrectly called this VI got recompiled and in order to save them I need to check out all the VIs are affected. If I only check out the file I need to modify and ignore other recompiled VIs the problem is if I use typedef ENUM and I still want the automatically updated VI got saved. Does anybody run into this problem?
    Thanks for help!
    Tom
(3,683 Views)
Yes, it can be a problem since LabVIEW stores the source and compiled code in the same file. There is an option to separate source from compiled code that addresses this problem. I have never used it and don't know if it causes any other problems.
LabVIEW 2012
(3,681 Views)
Hi Steve,
      Could you give more information or where can I find the information about how to separate source from compiled code?
     Thanks for help!
     Tom
(3,676 Views)
Accepted by topic author tom_z
(3,670 Views)
Hi Simon,
    It works. Thanks!
    Tom
(3,641 Views)
