LabVIEW will not uninstall
I attempted to uninstall a LabVIEW 8.5 license from a Windows 2000 machine.  The uninstall failed numerous times - it got to a "Validating Install" message and froze.
I then tried to install a different license over this install, which appeared to work for a time, but then it froze and refused to continue.  At this point I can neither uninstall nor install LabVIEW.  I have run into uninstall problems before and I believe a tool was made available which would clean the registry of all LabVIEW keys & data so an install could occur.
Any help you could provide would be appreciated.
Thank you.
(3,160 Views)
see:
http://forums.ni.com/ni/board/message?board.id=250&message.id=34373&requireLogin=False
Hope this helps
Now Using LabVIEW 2019SP1 and TestStand 2019
(3,152 Views)
Did MSI Blast fix the problem for you?
Justin Parker
Product Support Engineer
(3,122 Views)
