LabVIEW web server config - redirects/This site can’t be reached
I was trying to mess are you with LabVIEW's web server, and ended up screwing up the ports so that I can no longer connect to it when I click "configure web application server".
Now when I click "configure web application server", it tells me "This site can’t be reached".
If I try to manually connect through URL(http://localhost:3580), it will redirect me to http://localhost:21/, which gives me the same message mentioned earlier.
The reason I am trying to configure my web server is that I am pretty sure the web server was turned off after an NI/Windows update. I get an error message "invalid server IP address" when I try to load my HTML document that the web publishing tool creates.
All of this was working before, after windows update/NI update, it looks some settings got moved around and I am not sure what to do.
(2,876 Views)
When you say that you messed with LabVIEW's web server what do you mean?
Also why don't you list the steps you took in creating a web service so that we can get a better understanding of exactly what it is you are trying to accomplish.
(2,806 Views)
