LabVIEW vi
Can I time the execution time of a vi and display a message when the execution is over?
(3,898 Views)
It may be possible knowing what the VI does.
For example if the vi has a user interface it becomes difficult to calculate the same since evreything depends on the user.
However you can find out by trail and error how much time does a vi takes to execute by the snippet below. (non UI windows)
Message Edited by Guruthilak on 03-08-2010 05:21 PM
Regards
Guru (CLA)
(3,893 Views)
Or you can just monitor them in Performance and Memory/
Tools>>Profile>>Performance and Memory...
(3,888 Views)
See the attached VI
Shrek
Edit  :   Sorry guys i did'nt see the reply.
Message Edited by shrekt on 03-08-2010 05:29 PM
(3,885 Views)
You can use a pop up message as well..
(3,875 Views)
Also see...
http://decibel.ni.com/content/docs/DOC-6523
Rich Roberts
Senior Marketing Engineer, National Instruments
Connect on LinkedIn: https://www.linkedin.com/in/richard-roberts-4176a27b/
(3,828 Views)
