LabVIEW vi communication with MODBUS
hello
and thanks for your example
i want to communicate with some autonics power meter thru modbus
but i have some error
please check attached file and help me to solve my problem
Message 21 of 33
(3,122 Views)
Well, something is wrong with that subVI.  One error says it is already running, while the other says it is broken.  That is kind of contradictory.  There really should be nothing wrong with it since it is a built-in LabVIEW subVI.  Did anyone modify it?
Other than that, we can't help because you didn't attach any LabVIEW code that we can open up, look at, poke around in.
Message 22 of 33
(3,116 Views)
i'm using modbus libbarry and vi example that  mr Himanshu_Goyal  posted in  several previous page
Message 23 of 33
(3,099 Views)
Something is very odd about your VI.  I am wondering if it is somewhat corrupted.  It could not find MB Serial Init, and when I tried dropping a new one in it, nothing happened.  Only after I dropped it into a different new VI, and it asked me about resolving a conflict, was I then able to copy it into your VI.
Try deleting MB Serial Init.  Save and close your VI.  Reopen,  See if you can add a fresh one.
If that fails, rebuild the VI from scratch, it's not that big.
If that fails, then try reinstalling the MB library from http://www.ni.com/example/29756/en/  or https://forums.ni.com/t5/Reference-Design-Content/LabVIEW-Modbus-API/ta-p/3524019
Message 24 of 33
(3,096 Views)
Hi all, sorry to bump an old thread but I am having a similar problem. I was hoping to get some help with modbus parameter settings for my project. Here is a link to my thread;
https://forums.ni.com/t5/LabVIEW/MODBUS-parameters-for-VFD-communication-to-Labview/td-p/3586442
Any help is greatly appreciated, Thank you.
Message 25 of 33
(3,038 Views)
I've found you need to fix the CRC vi datatype bug to get rid of the transient read error, then the next issue is the speed of the routines. The implementation of the code is a mess; It reads only a specific address of the modbus map so reading or setting 6 channels takes 6 serial transactions...where one would do one read of the entire memory map for that datatype!.
I am going to fix this code and update a revised usable one, as soon as I can.
Message 26 of 33
(2,733 Views)
Hello Sir,
Your VI is working fine. But i am not getting output for "Read input register". I am getting output only for "read holding register". Those values are coming 65535. May i know why it is not working??
My application reading data from Energy meter TN 8400 using RS485.
Error display
Modbus register for energy meter.
Message 27 of 33
(2,648 Views)
Function code 4 is for Read Input Registers.  If you want to Read Holding Registers, then use function code 3.
Other than that, I can' help you because you haven't attached any code and really haven't adequately explained the problem you are having.
Message 28 of 33
(2,644 Views)
Thank you for response.
Finally i got the solution for that problem.
Energy meter sending the data in floating format. In modbus VI, i couldn't read the floating values. Even i tried to convert the values(what i am getting) into floating, but it doesn't work. So, i have used NI OPC server to read the values from the energy meter and i have interfaced NI OPC and my VI file. there after, i got the values based on modbus address.
Message 29 of 33
(2,610 Views)
Your solution is for a completely different problem than the one you stated where you said you were getting an error on read.
With Modbus, if you want floating point values, they tend to be single precision (4-byte) values.  You need to read two registers that are consecutive and combine those two 16 bit integers into a SGL float.  You can do that with typecast.  You might have to do something special depending on whether the high word is first or second of those two registers.
Message 30 of 33
(2,603 Views)
