LabVIEW to measure periodic time
I am using labVIEW to measure the periodic time of a pendulum using a photogate. I would like to know how I would start a timer when the photogate is activated the first time, then stop the timer when the photogate is activated the third time. Any advice would be much appreciated,
Kind Regards,
Patrick
(1,431 Views)
How is the Photogate interfaced with the computer?
Santhosh
Soliton Technologies
(1,419 Views)
The photogate will interface with the computer using a 6211 NI DAQ
(1,408 Views)
I would recommend using a counter task, specifically a finite buffered period measurement with at least 3 samples.  From your array of periods, you'll want to ignore index 0, then sum indices 1+2 for your oscillation period.
Index 0 will be the arbitrary time from when you start the task until the first active photogate edge is seen.  In many apps, it's meaningless and should be ignored.
(Note:  The initial meaningless interval is measured on older device designs like your M-series board.  A newer X-series device would suppress this initial interval so then you'd simply sum indices 0+1.  This change was made as a non-negotiable "favor" so the behavior is present *all* of the time, but it turns out it's only actually helpful *most* of the time.)
-Kevin P
(1,398 Views)
