LabVIEW startup error on XP tablet
I have installed and activated LabVIEW 8.0 on my Fujitsu T4020 Tablet PC with Windows XP SP2 (Tablet Edition).
When I try to start LabVIEW, I get the following error:
MICROSOFT VISUAL C++ RUNTIME LIBRARY
Runtime Error!
Program: ...ogram Files/National Instruments/Labview 8.0/LabVIEW.exe
R6029
- This application cannot run using the active version of the Microsoft .NET Runtime
Please contact the application's support team for more information
Closing this error closes LabVIEW.  Any ideas on a solution path???
(4,002 Views)
Officially we do not support LabVIEW ona  tablet pc but I do not see a reason why it would not work. What version of .NET do you have running?
Ankita
(3,973 Views)
Microsoft .NET Framework 1.1 + SP1
(3,967 Views)
I was searching on google for the error you are getting and one of the sites mentioned that it may be due to corrupt .NET framework. I would try uninstalling and re installing the framework and see if that helps. Also, have you seen this problem with any other programs as well or only LabVIEW?
Ankita
(3,942 Views)
Reinstalling the .NET software fixed the problem.  Thank you very much for your help.
(3,918 Views)
