LabVIEW searches the same file again and again
So, after setting the exact folder as first search path, it worked. That was the option I was looking for in the end...although I didnt know that at the beginning 🙂
By naughty default icon style you mean the ctls? Hmm yeah, I usually only change the icon of my functional VIs Smiley Sad
thanks for your help
Message 11 of 15
(1,160 Views)
If you dig through my uploaded images you will find one that contains a snip of a "Menu>>View>>Browse Relationships>>Unopened Type-Defs"  there are several HUNDRED controls in that view with the same default icon!  It made for a rather bad day.Smiley Frustrated Don't do that to yourself.  Edit the *.ctl Icons (Better yet, get some Icon Templates)
"Should be" isn't "Is" -Jay
Message 12 of 15
(1,136 Views)
Haha, sounds good, I will do this in the next time 🙂
Is there a possibility to change the templates default folder from C:\User\Documents... to another folder like Dropbox, because than I can share my templates. At the moment I always modify the icons from one PC as the other doenst have the templates and I am too lazy to make them two times.
Message 13 of 15
(1,113 Views)
Hi Slevin,
you can copy the whole icon templates folder from one PC to the other…
Message 14 of 15
(1,106 Views)
One advantage of this is when you view a cluster as an icon, you don't have to guess what it is because the icon will be self-documenting.
Bill
CLD
(Mid-Level minion.)
Message 15 of 15
(1,095 Views)
