LabVIEW runtime engine installation failed
When I install the LabVIEW Runtime Engine on different PCs at work, the installation fails.
Why? Because the installation script is looking for Netscape and Matlab versions that are installed.
Unfortunately, those 2 applications are installed on a network drive which is read-only and consequently the script is failing at this point because it's trying to install some files on the read-only network drive.
My question is: how can I disable (switch?) the detection of Netscape and Matlab in the script?
Many thanks for your help
Yann Leray
Scientist
Unilever Research
(3,529 Views)
I recommend disconnecting these computers from the network.
I have never had a problem with a runtime engine installation because I didn't have Netscape or Matlab, so the installation for your PCs should be successful with the network isolated.
(3,529 Views)
Thank you LabviewGuru, but Matlab and Nestcape have several keys in the registry and therefore the LabVIEW Runtime engine installation detects those key, even if the I'm logged as local administrator with the network off. I'll give another go.
Yann Leray
Unilever Research
(3,529 Views)
Unfortunately, it did not work again.
I need some help since I need to deploy an LabVIEW application on several PCs
Many thanks in advance
Yann Leray
Unilever Research
(3,529 Views)
