LabVIEW restarting COM port?
Hi guys.
I have app on ATmega and when comes request from Labview app, ATmega starts sending data throught UART/USB (FTDI chip).
So i use VISA in Labview:
I notice when i run labview app its always reboot my ATmega. Its the same if i just disconect and conect USB to ATmega .
If i run Labview continously i can read data one more time and then is mega rebooted.
Its HW or SW fault?
If i use HyperSerialPort app i can smothly send comand to ATmega and then see comming data.
(4,578 Views)
The tiny blurry picture is worthless.  No one can debug a picture.
(4,547 Views)
(4,531 Views)
Possibly one of the serial handshaking lines like RTS, or DTR is being used to toggle the  Atmega into a debug mode at the start so you are able to upload new firmware.
I believe that's how most Arduino's work and they are all based on Atmega chips
=== Engineer Ambiguously ===
(4,525 Views)
So always i run LabVIEW is rebootet bcs Mega thinks i upload new code?
In datasheets from Board:
Is written just TXD and RXD is conect to Mega(USART, RX to TXD and TX to RXD).
But still
makes sanse .
So its some way how to make Atmega dont go to debug mode from LabVIEW app?
(4,497 Views)
That is not the picture of the AT-Mega but the USB to RS-232 converter. And on there I see all the usual handshake lines like RTS, CTS, DSR, DTR and even DCD and RI signaling lines.
I would take a look at the VISA Initialize VI before your loop! I can't look at your VI as I only have LabVIEW 2018 installed on this machine but make sure the flow control is disabled (none). In addition you may need to force the RTS and/or DTR line state to a specific value after opening your port.
Rolf Kalbermatter  My Blog
(4,444 Views)
You have right
DTR is connect to reset, i need use JP5 to deactivate this function.
(4,438 Views)
