LabVIEW one button dialog fails in filter event
I'm using the one button dialog to provide feedback to the user in an event structure. Inside of a notify event, it works fine. I have another instance inside a filter event (Edit Cell? for a listbox). When it gets called, the dialog box appears to hang. I've noticed that if I select a window from another application (like Windows Task Manager), then come back it appears that the one button resets to the FALSE state and operates correctly. If I don't switch applications, the one button dialog is completely unresponsive.
The VI that I am running is top level, and set to Modal. I am setting the Discard? output to be TRUE in the cases where I provide the dialog. The dialog box works the first time, but fails on subsequent iterations. Perhaps the Discard? setting is affecting operation?
Thanks for your thoughts.
Derek
(2,652 Views)
Hi Derek,
i tried it with this vi and can´t see your behavior.
Mike
(2,637 Views)
Thanks. I see that your version works, even in LV 8.5.1.
I'm not sure what I did to get mine working. I rebooted and LV still had problems. After I deleted some code and rebuilt it, it seems to work fine now.
Derek
(2,609 Views)
