LabVIEW on Raspberry Pi
Hi All,
I've seen the LINX tool for deploying labview code on the pi. But this seems to be only useable with LV 2014 ?? Does anyone know if a 2015/16 version is in the pipeline or if it can be done ?
Other than that, is there any other way of running labview code on a Pi ?
Richard.
(4,753 Views)
Have you looked on the LabVIEW MakerHub forums?  I see that Linx 3.0 was recently (April?) released ...
(4,725 Views)
Beaglebone and PI still require LV 2014.
(4,719 Views)
You have to use LabVIEW 2014 32 bit version to connect to your raspberry pi,also you have to download  LINX, another package you going to use its Lab View control Design and lab View Math script, use que VI manager to install LINX and the go to tools>makerhub>LINX>LINX target configuration, in that window you going to put the ip adress of your raspberry and the default user and password, and the install the oackage to the raspberry and use it
@lvrichard wrote:
Hi All,
Richard.
(4,546 Views)
