LabVIEW on Apple Silicon M1 and beyond
Seems to work for me too with LabVIEW 2020 SP1. Only LabVIEW box checked as Chris said.
However no success installing LabVIEW Community - BSOD after reboot (Inaccessible Boot Device). Any idea ?
Rejean
Message 11 of 34
(4,655 Views)
Hey,
Thanks for sharing this useful information. Could you please help me to try installing DAQ assistances,and see if it is work? Lots of my NI project need these kind of tools,thanks!
Message 12 of 34
(4,633 Views)
I finally managed to get LabVIEW (2020 SP1) running on my new M1 Pro with Parallels 17 and Windows 10 ARM – after several tries resulting in an "Inaccessible Boot Device" error upon restart, the fix was simply to untick the "Disable Windows fast startup box". Hopefully this might be useful to others.
Message 13 of 34
(3,973 Views)
You know, that's interesting because NI recommends that you disable fast startup in BIOS for a physical PC.
Bill
CLD
(Mid-Level minion.)
Message 14 of 34
(3,962 Views)
Just curious, what benefit do you get running LV inside a VM (Parallels) of Win10 on Mac (other than you don't have access to a Windows machine) than natively on MacOS?
Santhosh
Soliton Technologies
Message 15 of 34
(3,959 Views)
I think the original issue was that it won't run on the latest Mac chip.
Bill
CLD
(Mid-Level minion.)
Message 16 of 34
(3,949 Views)
But it does as Chris pointed out, although it's not a simple point and click experience. More likely it was a license issue as pre 2021 you had separate licenses for Windows, Mac and Linux.
Rolf Kalbermatter  My Blog
Message 17 of 34
(3,921 Views)
I should check my verb tenses.  I should've said "didn't" run, instead, implying that it does run now.
Bill
CLD
(Mid-Level minion.)
Message 18 of 34
(3,890 Views)
Actually the main reason is that I need to deploy VIs to Windows machines eventually. Since I cannot build them from the macOS LabVIEW version, I use Parallels.
Message 19 of 34
(3,887 Views)
VMs are very handy for having different versions of LabVIEW installed separately. We're using VMWare in our team on Windows, Linux and Intel Macs, sharing the same virtual machines between us.
DSH Pragmatic Software Development Workshops (Fab, Steve, Brian and me)
Release Automation Tools for LabVIEW (CI/CD integration with LabVIEW)
HSE Discord Server (Discuss our free and commercial tools and services)
DQMH® (Developer Experience that makes you smile )
Message 20 of 34
(3,564 Views)
