LabVIEW object oriented programming issue
I am learning LV OOP nowadays, and I have some questions about it. I used LV classes to replace the sub VIs, such as File I/O VI, or device driver VI. But when it comes to main VI, I had to use the traditional producer-customer framework. It's not true LV OOP, but how can I use LV OOP to develop the main VI or top level VI?
(2,605 Views)
Accepted by topic author GrayJoker
Classes do not replace VI's. If anything they might replace your use of clusters or other data types in some situations.  I would read this if you have not already:
LabVIEW Object-Oriented Programming: The Decisions Behind the Design
(2,573 Views)
