LabVIEW load error code 3: Could not load front panel (LabVIEW 2014)
Good day!
Decided to use the new version of LabVIEW 2014 patch 1!
Week everything was fine and suddenly, after the usual save and exit LabVIEW 2014 ceased to open the main .vi file:
Writes an error:
LabVIEW Generic error:
An error occurred loading VI 'KM_200.vi'.LabVIEW load error code 3: Could not load front panel.
Copies of this .vi certainly did, and worked on it for 6 months!
Please somebody help with the restoration of the file!
Message 1 of 9
(6,560 Views)
Accepted by topic author mnml_mouse
Hi mnml,
can't you backup any of those copies you mentioned?
Message 2 of 9
(6,557 Views)
Hi mouse,
so you sent me your backup containing the whole project. What am I supposed to do with it?
Message 3 of 9
(6,360 Views)
you asked me for another copy of the draft, I thought you could help me restore that file KM-200.vi
Message 4 of 9
(6,353 Views)
no, I didn't ask you to send your backup to me! You should just use your backup to restore the screwed file…
Your backup seems ok, I could open all the VIs. You should clean up the code anyway, refactoring seems a good idea too…
Message 5 of 9
(6,346 Views)
but how can I restore the attached file KM-200.vi ?
Message 6 of 9
(6,333 Views)
Hi mnml,
the attachment of your first message shows that error 3. Use the one from your ZIP backup…
Lesson learned: Use SVN (or any other similar tool) to implement full source code control.
Message 7 of 9
(6,289 Views)
I have the same problem. How can I fix this ? Smiley Sad
Would somebody help me?
I attached my crash vi
Message 8 of 9
(6,105 Views)
Continued here
Message 9 of 9
(6,067 Views)
