LabVIEW linker.cpp, line 1939 error
Occasionally LabVIEW 7.1 would crashes after certain numbers of tests had been run giving the following error message: Linker.cpp, line 1939.  I've looked up what this error message means, and I don't have any VIs or subVIs with the same name at all.  What else could cause this error message to occur and why doesn't it occurs consistently?
(2,961 Views)
Do any of the VI's or subVI's have names similar to existing VI's in the palettes?
After how many tests does the crash happen? (Is there any way to predict when the crash will happen?)
Does it always crash at the same point in your application?
(2,940 Views)
