LabVIEW is a Language or Tool??
Hi All,
There are few arguements I am facing since 1.5 yrs :
1. I would like to say LabVIEW is a language like C, C++, Some people will argue like it is a Tool.( I wont say its not a tool but more than that i prefer to say its a language)
2. As per i heard in NI Conferences there is a G code running inside the LabVIEW functional blocks( like add,subtract, loops etc). but people say that there is a C,C++ Java  code running inside that. Is it?
Please share your views
Correct me if I am wrong.
Best Regards
Manasa M
Message 1 of 18
(6,860 Views)
What is LabVIEW?
Cheers
--------,       Unofficial Forum Rules and Guidelines                                           ,--------
          '---   >The shortest distance between two nodes is a straight wire>   ---'
Message 2 of 18
(6,849 Views)
Another What is Labview?
aputman
Message 3 of 18
(6,840 Views)
Message 4 of 18
(6,834 Views)
LabVIEW is the name of the Development Environment (IDE) - e.g. like Visual Studio.
G is the name of the graphical programming language you program with LabVIEW.
As for your second question - like other languages, you can compile your LabVIEW (I really mean G here, but it's more common to refer to it as LabVIEW) code into DLLs and call them from other languages and also call code written in other languages (e.g. .NET / C DLLs) from within LabVIEW. I believe that quite a lot of the LabVIEW IDE and some of the functions are written in G itself (a term called dog-fooding) and some of them are written in other languages (e.g. C++).
(blog)
Message 5 of 18
(6,820 Views)
Graphical Programming language Smiley Very Happy
Best Regards
Manasa M
Message 6 of 18
(6,811 Views)
Thanks for the reply Sam 🙂
Best Regards
Manasa M
Message 7 of 18
(6,797 Views)
Sam_Sharp wrote: I believe that quite a lot of the LabVIEW IDE and some of the functions are written in G itself (a term called dog-fooding) and some of them are written in other languages (e.g. C++).
My current understanding is that the core of LabVIEW is written in C# now (once upon a time, it was C++, likely C before that) and then much of the IDE (like Quick Drop) is written in G.
Message 8 of 18
(6,754 Views)
I've heard the argument that something like LabVIEW is not technically a language unless it can compile using itself.  For instance... C code is compiled using C.  But I honestly treat LabVIEW as a language.  Only because as I throw down For Loops and While Loops I am thinking in terms of text based code.
Throw down a For Loop and attach an initialized array into the walls and I have successfully written:
For int i = 0; i++; i<=Size Of Array_TestArray   (something like this, syntax probably not 100% accurate)
So... in my mind this is a visual language.  If Sign Language (which is visual) is considered a language, then so is LabVIEW.  *Mic Drop* haha
Message 9 of 18
(6,737 Views)
This sounds right. Last NI core developer I talked to said he spent half his time in C# and the other half using G.
Cheers
Message 10 of 18
(6,731 Views)
