LabVIEW integration into CAPL
Can some one share information for the following queries,
Is there any possibility to call LabVIEW VIs in CAPL (CAN Access Programming Language)?
(or)
Is it possible to convert the LabVIEW VIs as API that can be used in CAPL (CAN Access Programming Language)?
Thanks in Advance.
Thiru.
(3,569 Views)
Can you call a dll or ActiveX from CAPL ?
A vi can be interfaced via ActiveX or you can build a vi to a dll or exe.
(3,556 Views)
Hi there,
or by any mean there is solution to do vice versa?
(3,188 Views)
