LabVIEW front panel gets corrupted : bottom half doesn't update/scroll anymore.
@altenbach wrote:
I see the same problem. It gets fixed once you set the minimum panel size back to 0,0 in the windows size property page. I think it has to do with this setting.
I can confirm this!
Kudos are welcome...
Message 11 of 16
(818 Views)
Only one of the VI's (the less urgent one 🙄) has the minimal window size set to something else but 0,0.
So this is not the root cause 😢
Setting to (0,0) doesn't fix it for me.
Message 12 of 16
(809 Views)
A temporary fix that works (during runtime)
Move the window bounds programmatically 1 pixel every second (and back).
I can force the issue to apear mostly by putting another application frontmost and then switching back to labview.
when scrolling the issue apears, and gets fixed when the window moves a pixel.
However this is a VERY temporary fix.
Message 13 of 16
(797 Views)
Hi Thomas,
played around a lot with your Interface_2. I see the flaw in edit mode, usually very fast when pulling from one screen to another or after resizing the frontpanel manually. Maximizing the window fixes it. But you are correct, it will appear again. I even tried to save in LabVIEW 2020, then convert back to 2019, giving your tab control a color other then transparent, removing some of the decorations. No effect.
Sorry, I have no solution for you other than recreating the VI (I know you said that's not a solution... - and you already know about that).
It's a known fact that sometimes something in a frontpanel might get corrupt (after many saves and/or after several LabVIEW version upgrades).
Regards, Jens
Message 14 of 16
(792 Views)
Yes, Sorry I only looked at one of your VIs (on a laptop currently). I still think the main problem is the immense number of overlapping objects. I'll have a look at it on a better computer later.
Message 15 of 16
(783 Views)
@ThomasV  ha scritto:
The uid-option also allows me to translate static texts on the front panel.
Thx!
Obviously, finding and correcting the problem would be the best.  Maybe altenbach is right pointing against the high degree of overlapping.
What I meant is that I do the same thing: translating text. However, rather than use "static text" (i.e. free labels), I place transparent string indicators (disabled) whenever a caption is not available. I think it's a viable alternative, unless you have tons of strings around.
Paolo
Message 16 of 16
(728 Views)
