LabVIEW exits without notice
I am also having this problem! (just now!)  I am using Windows XP and LabVIEW 2010.  The listed errors are random - yesterday there was no error message or log just the shut down.  The error from this morning is below however incase anyone has any thoughts on it....
-Diana
ERROR MESSAGE:
#Date: Fri, Sep 24, 2010 9:53:14 AM
#OSName: Microsoft Windows XP Service Pack 3
#OSVers: 5.1
#OSBuild: 2600
#AppName: LabVIEW
#Version: 10.0 32-bit
#AppKind: FDS
#AppModDate: 06/25/2010 19:14 GMT
#LabVIEW Base Address: 0x00400000
Insane backup object at BDHP+1274ADA0, UID 19987, in "AFT Core Functions2.vi": {index } (0x2): Label (COSM)
Insane backup object at BDHP+1274AE20, UID 19995, in "AFT Core Functions2.vi": {index } (0x2): Label (COSM)
Insane object at BDHP+11A5C94C, UID 2, in "AFT Core Functions2.vi": {index } (0x2): ObjHeapHdrExtension (GNRC)
9/24/2010 10:38:12.768 AM
c:\builds\penguin\labview\branches\2010\dev\source\panel\fpsane.cpp(442) : DAbort: Fatal insanities(0x00000002) exist in ReportInsanities, 'AFT Core Functions2.vi: EDIT__NI-PXI8101-2F11E877__{507F8EEE-D1B7-40E1-A86E-B55348E1A1F4}'
$Id: //labview/branches/2010/dev/source/panel/fpsane.cpp#7 $
0x00F501AE - LabVIEW <unknown> + 0
0x0102BFA2 - LabVIEW <unknown> + 0
0x010345B1 - LabVIEW <unknown> + 0
0x01035606 - LabVIEW <unknown> + 0
0x01035DDB - LabVIEW <unknown> + 0
0x01036E62 - LabVIEW <unknown> + 0
0x01663111 - LabVIEW <unknown> + 0
0x01600EF6 - LabVIEW <unknown> + 0
0x00A1CEB0 - LabVIEW <unknown> + 0
0x00A1D0CD - LabVIEW <unknown> + 0
0x00A1D48E - LabVIEW <unknown> + 0
0x01AF0F96 - LabVIEW <unknown> + 0
0x01B8D905 - LabVIEW <unknown> + 0
0x01AE52FC - LabVIEW <unknown> + 0
0x01B11768 - LabVIEW <unknown> + 0
0x01B8CEE9 - LabVIEW <unknown> + 0
0x01B109C1 - LabVIEW <unknown> + 0
0x00444E11 - LabVIEW <unknown> + 0
0x004450CA - LabVIEW <unknown> + 0
0x00445197 - LabVIEW <unknown> + 0
0x01CF7DBB - LabVIEW <unknown> + 0
0x7C817077 - kernel32 <unknown> + 0
Message 21 of 23
(1,255 Views)
Hi Diana,
This was reported to R&D (# 246099) for further investigation.  In order to find a workaround for this, it would be helpful to narrow this down to a particular VI or set of code that can consistently reproduce the error.  If you can consistently reproduce the error, then we can identify what is causing it and eliminate that from the code.
Thanks for the feedback.
Tejinder Gill
Visit ni.com/gettingstarted for step-by-step help in setting up your system.
Message 22 of 23
(1,235 Views)
"Save Often".
This consistently saves an insane object. What happened to the old popup window that clearly stated what & where the insane object was? I thought I was golden because I haven't seen one in a long time, but instead I get the disappearing LabVIEW for more frequently than ever before.
Less features, more stability please.Smiley Wink
Message 23 of 23
(1,206 Views)
