LabVIEW.exe-Application Error
How do I stop this error from happening? It seems to be a random act of damage.
(3,406 Views)
do you have any more specifics on the issue? What version of LV, what are you doing when the crash occurs (running a VI or editting), can you reproduce it, etc. Also, is there anything else reported with the crash, (error number, line number, module, .cpp file name, etc).
(3,406 Views)
I am running ver 7. The crash always occurs when I am running the VI.
The error is:
The instruction at "0x00c01e0e" referenced memory at "0x05003231". The memory could not be "read".
Also, my cpu usage tops out when running vi's. (Win2K)
(3,406 Views)
which VI is giving you the error. One that you wrote or one that came with labview.
Post your code and let us have a look. there are more possible answers than we have time to write as to what could cause this.
Joe.
"NOTHING IS EVER EASY"
(3,406 Views)
also one other thing if this is already an executable does it work in design time. It sounds to me like there may not be any wait functions in any of the loops which will cause the cpu usage to max out.
Joe.
(3,406 Views)
