LabVIEW doesn't work with .NET 3.0?
It seems LabVIEW doesn't work with .NET 3.0.   Get error 3 from the constructor node.
No error on .NET 2.0 pc with the same C# dll.
Please see this thread:
http://forums.ni.com/ni/board/message?board.id=170&thread.id=354796
George Zou
(3,063 Views)
zou,
Is the error a LabVIEW Error that you are receiving or a Windows Error?  Could you post a screenshot?  I'll then do some research and see if I can find anything out.
Jared Boothe
Staff Hardware Engineer
(3,023 Views)
Problem solved.  .NET 3.0 is fine.
It was the path.  One of the directory is "C#".
LabVIEW doesn't like C# in the path at runtime. although it's ok in edit mode.
In the edit mode, LabVIEW still can find all the methods and properties.
George Zou
(2,975 Views)
