LabVIEW crashes with ntdll.dll!7C911e58 as the error in debugger.
I am running a streaming video application (VLC) in LabVIEW as an activeX control. There are 6 separate containers with different streams in each.
Labview Crashes citing ntdll.dll!7C911e58 as the error in debugger when I try to run the VI.
As well, every 4th attempt to run the VI results in the BSOD.
Does anyone know what I can do to try and fix this serious error?
Sean
(3,045 Views)
Sorry, forgot the OS:
WinXP Pro, LV 7.2
Has anyone else had this problem before?
(3,029 Views)
Which version of LabVIEW do you have?  There wasn't a LabVIEW 7.2.  Did you mean 7.1.1?
Did you get an error log generated?  That would be useful in diagnosing the problem.  This KB reviews its location:
http://digital.ni.com/public.nsf/allkb/54E361E3FF477EC186256C320068184F?OpenDocument
Trey B
Applications Engineering
(3,020 Views)
