LabVIEW crashes while building PPL
Hi Everyone,
Each time I try to build packed project library with VI which contains 3D graph LabVIEW crashes.
Does anybody know the reason, or possible solution to successfully build the library.
Thanks in advance.
Arev
CTO | RAFA Solutions
(4,451 Views)
Hi Arev
I have same problem with you. And I try to create execute file is OK.
Just share my experience
Benny
(4,181 Views)
Hi Arev
I recommand that you use 3D Graph instead of Surface.
Benny
(4,172 Views)
Hi Benny,
Thank you very much for the suggestions. After some investigations, it appears the problem is with XControls, and Surface graph is based on it.
Due to some functionality missing in the 3D graphs, still I have to use Surface graphs.
Arev
(4,157 Views)
