LabVIEW crashes when I try to open my project
When I open LV and select my project from the Open pane, all I get is a popup that states:
"An unhandled win32 exception occurred in LabVIEW.exe [3260].  Just-In-Time debugging this exception failed with the following error:  No installed debugger has Just-In-Time debugging enabled.  In Visual Studio, Just-In-Time debugging can be enabled from Tools/Options/Debugging/Just-In-Time.
Check the documentation index for 'Just-in-time debugging, errors' for more information."
then quits.  Any ideas?
(3,748 Views)
Hi there
try to open prior versions of your project or the current version with a different LV installation. if possible post your complete project (please give us some information about versions of LV and OS).
Best regards
chris
CL(A)Dly bending G-Force with LabVIEW
famous last words: "oh my god, it is full of stars!"
(3,745 Views)
Unfortunately, there is no way I can post my whole project.  It is proprietary.
I am running LV 8.5.1 on WinXP Pro SP2.
(3,741 Views)
Can you open all the projects VIs from outside the project without problems?
Best regards
chris
(3,738 Views)
Before you sent this reply, I copied the project to my desktop so it couldn't open any VIs.  The project file opened fine even though the VIs were not present.  Then I saw that my cFP tree had yellow ! triangles on each item so I deleted the tree, saved the project, and copied it back to its home directory.  The project file then opened fine, I reinserted the auto-populating folder for my code, and saved.  It opened fine the next try.  So I guess my cFP configuration is hosed.  Maybe I did it wrong.
(3,730 Views)
Hi kc64,
I was confused with your last post. Are you still having problems with your cFP tree?
RIO Embedded Hardware PSE
CompactRIO Developers Guide
(3,686 Views)
At this time, I believe I have isolated the problem to the IAK file.  That IAK file seems to give me no end of problems.  I have the latest copy backed up is Visual SourceSafe so I can pull it out when the working copy gets corrupted.  At this point, the problem is hibernating so I am able to continue working.
(3,680 Views)
