LabVIEW crash and .dmp file
Hi, I have a TestHarness.exe file which calls a LabVIEW FPGA dll and this has worked fine for some time, however, I had a TestHarness crash which I have never seen before
This points to a LabVIEW Data folder which contained a lvlog.txt file and a .dmp file.
How can I view the .dmp file?
(5,138 Views)
Dump files are for NI, see:
https://forums.ni.com/t5/LabVIEW/Dump-file-analysis-help-please/td-p/3614819
https://www.ni.com/en/support/documentation/supplemental/18/ni-error-reporting--nier--faq.html
Otherwise, I would check with the program's developer.  They may have more insight on the issue you are experiencing.
ALE Consultants
(5,109 Views)
