LabVIEW converts a .NET - stringtype into an unusable refnum
I use the .Net Webservice browser to convert a WSDL-file from the local network into an assembly(DLL).
With a Invokenode one of the methods is selected. The return parameter was recognized as a boolean. The input was recognised as string (purple colour). But the resultvalue should also be a string. The outputline gets the symbol of a refnum with the value 'System.String&'.
My question: Is it possible to extract the string itself from the refnum-pointer or what did I do wrong?
This is the C# function that is used at the production of the WSDL-file.
[WebMethod]
public bool GetParameter(string Key, out string Value)
bool bSuccess = true;
Value = "";
try
iTest.GetApplicationParameter(Key, out Value);
catch (Exception e)
Value = e.ToString();
bSuccess = false;
return bSuccess;
(2,697 Views)
No, you did the right thing. In LV 7.x the code couldn't handle the reference type directly inside of LV and so the reference was turned into a LV refnum. This has been changed in the next version.
The fastest solution is to create a little helper class that has a get/set property for a string reference. This would be a lot easier than the other solution I can think of, which is to call the reflection API directly.
The class would look something like
public static String GetString(ref String arg)
return arg;
public static void SetString(ref String arg, String newValue)
arg = newValue;
(2,690 Views)
