LabVIEW built DLLs as a plugin system for a LabVIEW executable
Hello all,
I'm working on a project where we are attempting to package stand alone modules of our code base into LabVIEW built DLLs that will be called from a LabVIEW executable when that portion of the code base needs to be shown to the user.  I've run into issues trying to get more than one LabVIEW built DLL (with a user interface) to show on the screen at a time.  I've attached a zip file with an example project that contains two "plugins" and a calling application.  I'm working in LabVIEW 2018 64 bit on Windows 7.  Please take a look and see if you can replicate my issues and provide any help!
Steps to reproduce:
1.  Build exe or dll in each project.
2.  Run executable.
3.  Start Test 1 plugin.
4.  Start Test 2 plugin, notice that Test 1 plugin disappears, and Test 2 plugin appears.
5.  Start Test 1 plugin again.  Test 1 plugin and Test 2 plugin should both be running now.
Why won't Test 1 plugin stay up when I start the Test 2 plugin?  Why does Test 1 plugin show after I start it the second time (in step 5)?
Thanks!
Chris Davis
Message 1 of 1
(2,293 Views)
