LabVIEW + bluetooth
How are you disabling the bluetooth port? It sounds like it is not actually disabled since you are still communicating with your device.
When you run highlight execution, do you see at which part of your program the VI is hanging?
Message 11 of 14
(917 Views)
Before  while loop i get  the error, I will change the driver  of bluetoth with Bluesoleil, maybe works.
Message 12 of 14
(903 Views)
I think  I solved  the problem  I put  Bluesoleil version 10 and  work  great nok, I hope   will never  give any  problem. Thanks for   you're time man.
Message 13 of 14
(883 Views)
Glad that worked for you!
Message 14 of 14
(869 Views)
