LabVIEW and write protected DLL files
We are building Labview dll's within a source controled environment (ClearCase). These dll's can only be modified in a particular view, but they should be useable in other views. The problem is that LabVIEW seems to be unable to open and run a write protected dll. I don't want to do any unreserved checkout, i want to use automatically the latest version of these DLL's, but they are always write protected.
Does anyone runs in the same poblem and solved it?
Sunny
(4,004 Views)
it's not correct, that LabVIEW is unable to work with write protected DLLs!
So, please reword your questions more detailed!
regards,
Thomas Sandrisser
(4,003 Views)
We use German Version of LabVIEW 6.1 and there is displayed an error message "Zugriff verweigert" in case of loading any VI referencing a DLL with Checked In state (we use ClearCase).
I made a copy of one of these dll files and set the write protection flag manually, the error message isn't generated (as you described). So it seems to a problem in interworking between LabVIEW and ClearCase!
We are working with ClearCase Dynamic Views and MVFS (Multi Version File System).
Any help will be appreciated!
Sunny
(4,003 Views)
i don't know something about the 3rd p. software sorry!
perhaps it's an option for you, to program an application, which copy the dll file into a new folder with "normal" attributes!
regards,
Thomas
(4,003 Views)
I know that the last message was post a long time ago, but I would be interested by a reply also, because I necountered exactly the same problem with Labwindows CVI 8.0 and clearcase 6.0. I mean :
My executable calls some DLL.
the DLL are managed by clearcase and not checkedout.
I have an error launching the executable.
If I just copy/paste the source folder from clearcase to a temp directory, then CVI executes normaly the project. It is the same behavior if I checkout all dll called by the executable.
I thought that calling a dll requires only read access!!!
Is anybody can help me?
PFD
(3,842 Views)
Hi PFD,
You are correct that the dll need only to be read-only.  Unfortunately this alludes to ClearCase being the culprit. I would try the previously posted suggestion of programmatically copying the files.
Have a great day,
Ecleamus R.
(3,822 Views)
