LabVIEW and Multisim Co simulation Error 2366
Hey All! I am importing Multisim Design in LabView as an external model through Control and Simulation Loop. The Problem is every time I run my simlation in LabVIEW, it gives me an error "Error -2366 occurred at External Model in Single_Phase_Inverter_NI_Project.vi/Control & Simulation Loop" with possible reason being unupdated extrenal model which is not the case . Will some one help me ? I'm atttaching my files, too . Regards,
(5,560 Views)
Hi HamnaAhmad,
Could you post your code & a screenshot of the error?
Is your Multisim Design working successfully without importing it into the Control Design and Simulation Loop?
Nadine H.
(5,498 Views)
Hey!
I am attaching my files and the snapshot of the error, too. Multisim 14 gives alot of convergence errors which I don't know how to be eliminated. Please help.
(5,477 Views)
And yes, it is fine without importing it in labVIEW.
(5,475 Views)
Hi HamnaAhmad,
It looks like you're encountering a convergence error within your Simulation that is manisfesting in your Control Loop. Could you take a look at the following document which describes some Simulation errors and ways to fix them?
Nadine H.
(5,442 Views)
No , It didn't help .
Can you suggest another way ?
(5,403 Views)
Hi HammaAhmad
There are a couple of questions I want to make you regarding this situation:
Are you seeing this error meanwhile you execute your VI or do you have a broken arrow?
Are you getting any error on your Multisim Circuit, for example wrong output values?
Do you have the Co-simulation installed on your computer?
Are you able to create a very simple circuit and call it from LabVIEW?
Warm regards
(5,369 Views)
