LabVIEW and LEGO NXT blocks
Hi. I'm trying to integrate a linear actuator with the LEGO NXT software. Does anyone have any experience with creating a new block in LabVIEW and importing it into LEGO? Alternatively, has anyone successfully modified an existing block? I've read through the NXT_Creating_Mindstorms_Block.pdf but was unsuccessful in seeing the changes I had made while following the tutorial. I'm not having any luck figuring out where I went wrong.
(3,096 Views)
As an alternative, does anyone know how to modify the motor block for importing into the LEGO software? By this I mean modifying the config.vi, the draw.vi, etc. Is it possible to modify the existing vi's? I couldn't locate them in the addon Toolkit vi.lib folder and wasn't sure even I would even have access to them. Any assistance with respect to this would be greatly appreciated.
(3,091 Views)
Leanne,
There is a separate forum dedicated to the LabVIEW Fans of LEGO, if you post your question there you will probably have more success.
This forum can be found here.
(3,075 Views)
Thank you. I have posted my question on the other forum you suggested. Fingers crossed, I get a response soon. 🙂
(3,021 Views)
