LabVIEW and Email
I am wrting a routine for a remote monitoring station. Does anyone know of a
VI that can be used to send and/or receive email for instruction and warning
messages?
Yours sincerely,
Chris McCrory
Project Engineer
_________________________________
E-mail: c.mccrory@sp-tech.com
Website: www.sp-tech.com
Tel: 01382-622226
Fax: 01382-622565
(4,120 Views)
"Chris McCrory" writes:
> messages?
Chris,
That's easy with unix: Just use the system exec.vi with a command like:
cat message.txt|mail -s Subject you@isp.com
For Microsoft systems it's a little bit more complicated. Keep in mind
that smtp uses TCP port 25 and a telnet like syntax... You don't need
Active X or the Internet toolkit.
Johannes Niess
(4,120 Views)
The ni ftp site has an smtp example library that I have used to send email
successfully on UNIX and NT.
Jim
> > messages?
> Chris,
> Johannes Niess
(4,120 Views)
Hi From Belgium.
If this can help, a colleague of mine wrote a vi to send mail through MS
exchange using all its perks. His name is Pierre Ripak at
pierre.ripak@advalvas.be. If MS exchange is on your Windows the vi is develishly
simple to use. Ask him for a copy.
Gérard D'Ans
> messages?
> Yours sincerely,
> Chris McCrory
> Project Engineer
> Tel: 01382-622226
> Fax: 01382-622565
Regards Meilleures salutations Met vriendelijke groeten Mit freundlichen Grüssen
Gérard D'Ans
Labor
elec: gerard.dans@laborelec.be 32 2 3820568 fax 32 2 3820241
Université Libre de Bruxelles: gdans@ulb.ac.be 32 2 6502515 fax 32 2
6502710
URL site: http://www.ulb.ac.be/polytech/laborulb/index.htm
(4,120 Views)
Hi Chris,
I´ve written a VI, that can send emails using the exec.vi and a little
program of just 28kB.
If you´re interested I´ll send it to you.
Ciao
Max
(4,120 Views)
Max,
I would like a copy of your VI if possible. It would be a big help in our lab.
Jeffry Windsor
jeffry.windsor@ericsson.com
(4,120 Views)
