LabVIEW - XML
Dear Abdullah,
I had look to the ActiveX class what I used.
I used at first the Microsoft XML, Version 2.0 - Type Library
and the DOMDocument - Object.
At second I used the Microsoft XML, Version 3.0 - Type Library
I installed the Microsoft XML Parser but I didn`t find the Microsoft
XML Parser ActiveX class.
I use the Operation System Win98 and the LabVIEW Version 6.0.
Can you mail an example to me?
Thank you!
Greeting Sascha Sickel
(3,170 Views)
Hummm yes you are using the correct class. This is exactly what i meant. I wonder why you are getting errors?
Unfortunately i don't have an example right now but last time what i did is that i wrote from code in VB and then translated that to labview properties and methods and it ran ok. Does the stuff work OK 4 you in VB? Try some examples from MSDN website.
Abdullah
(3,170 Views)
Abdullah wrote:
>Hummm yes you are using the correct class. This is exactly what i>meant.
I wonder why you are getting errors?>>Unfortunately i don't have an example
right now but last time what i>did is that i wrote from code in VB and then
translated that to>labview properties and methods and it ran ok. Does the
stuff work OK 4>you in VB? Try some examples from MSDN website.>>Abdullah
Ok, thank you!
Sasch
(3,169 Views)
