LabVIEW - XML
I looking for a solution for XML with LabVIEW.
I will open an exist XML-File and replace a value from a
Note.
I wrote a Visual Basic programm that
describe the value from a certain note.
I tried to write a accordingly programm with LabVIEW. I used a special ActiveX
Class and used the same methode and property just like in the Visual Basic
programm.
But my LabVIEW programm doesn't work!
I don`t no what the reason is.
Is there anybody who have the problem, too, or have a solution or a answer?
Thank you!
Greetings from Germany.
Sasch
(3,436 Views)
I don't know what ActiveX class you are using but i have used Microsoft XML Parser ActiveX class and it runs OK when called from LabVIEW.
You can read and write attribute to/from XML file. Try XML parser if you are not using it already. you can download that from microsoft website.
Abdullah
(3,436 Views)
Abdullah wrote:
>I don't know what ActiveX class you are using but i have used>Microsoft
XML Parser ActiveX class and it runs OK when called from>LabVIEW.>You can
read and write attribute to/from XML file. Try XML parser if>you are not
using it already. you can download that from microsoft>website.>>Abdullah
Thank you, Abdullah!
I don`t know what ActiveX class I using,I will try it tomorrow.
I write the result.
Greeting Sasch
(3,436 Views)
