LabVIEW Webbrowser and Windows 10
Does anyone know how to get Microsoft Edge to appear in the LabVIEW Webbrower ActiveX window, and not in its own window? ...  cheers, George
Message 1 of 13
(12,726 Views)
Hey George,
Can you tell us what you have tried so far and clarify the behavior that you are seeing?
I found this example code in the community code exchange:
Simple LabVIEW Web Browser
I hope it helps!
Cheers,
Saki K.
Message 2 of 13
(12,660 Views)
Hi George,
does MSEdge even support any kind of ActiveX remote control?
You might read posts like this in the Microsoft® forum…
Message 3 of 13
(12,649 Views)
Thanks ...
The VI I am using worksed fine on Win7  ...  the HTML file would open in teh webbrowser window.  On Win10 it opens Edge as a separte application in it's own winow on the desktop
George
Message 4 of 13
(12,630 Views)
Thanks GerdW,
Yes it looks like Edge does not support ActiveX
I found that IE11 is installed, but was not activated, it is now. However I cannot remove Edge or make IE11 the default browser.
Can't say I am a big fan of Microsoft
Cheers,
George
Message 5 of 13
(12,617 Views)
It doesn't work with "Default programs" and changing Edge to IE11? Should work.
/Y
Qestit Systems
Certified-LabVIEW-Developer
Message 6 of 13
(12,589 Views)
Thanks evryone  ...  IE11 worked  ...  cheers, George
Message 7 of 13
(12,563 Views)
Are you trying to display it in a WebBrowser control on the front panel? It is possible to specify (using a registry key) which version of IE is used in the WebBrowser control - it defaults to something stupid like IE7. It's still internet explorer though - Edge doesn't have the same 'embedding' capabilities that IE has.
(blog)
Message 8 of 13
(12,547 Views)
Thanks Sam,
Yep I am displaying pdfs in a LabVIEW web browser through activeX.  It worked in Win7 but not in Win10.  I enabled IE11 and made it the default browser,  but I had not installed Adobe  ...  seems obvious but I did not do the original code and was not sure what was going on for some time.  All is now working.
Cheers, George
Message 9 of 13
(12,534 Views)
If you already have Adobe installed, and want to display a PDF, why not use the Adobe ActiveX control to display it?
http://forums.ni.com/t5/Example-Program-Drafts/Display-PDF-in-Dialog-box-in-LabVIEW/ta-p/3506322
Then you don't need to worry about browser versions installed.
Message 10 of 13
(12,510 Views)
