LabVIEW VI will not execute -- confusing error message
I am using an non-National Instruments DAQ board but I believe it has been configured correctly.  When I run the VI I get an error message (see attached file).
Error -1 orrcured at daqOpen
called by: IO_AI Group Config
called by IO_AI Control
I get this same error with several VIs.  Any ideas?
(3,120 Views)
What version of LV?
Manufacturer/Model of DAQ card?
Is it advertised as LV compatible?
Are there LV drivers for it?
Does the card show up in MAX?
(3,113 Views)
What version of LV?
  =  LabVIEW v6.1
  = IOtech / DAQBoard 2000 Series
  = It is LabVIEW compatabile
  = Yes, they are installed and the IOtech submenu's are available
  = No, it does not show up on MAX (I was told it was not supposed to though)
Wheels within wheels / In a spiral array
A pattern so grand / And complex
Time after time / We lose sight of the way
Our causes can't see / Their effects.
(3,106 Views)
Correct, it won't work in MAX.
Are the IOTech supplied vi's working? That may be a place to start.
(3,101 Views)
