LabVIEW UART Rx/Tx avec daqmx
Bonjour,
Je développe actuellement un banc de test avec LabVIEW. Je vais utiliser des modules NI style USB-600 et des câbles TTL-232R-3V3 pour communiquer en Rx/Tx avec mon outil.
Tout ceci fonctionne mais je voudrais savoir si il est possible d'utiliser DAQmx pour communiquer en Rx/Tx ou si il existe un module NI qui soit composé d'entrées analogiques, de sorties numériques et de Rx/Tx ?
Cela me permettrait de gagner un port USB sur mon PC.
Merci d'avance. Bien cordialement.
(1,687 Views)
How much engineering hours do you have available? Implementing your own RS-232 interface with digital or analog signals is not impossible but a lot of work for a very mediocre result.
- The resulting interface is electrically NOT RS-232 compliant without extra hardware.
- The achievable baud rates will be extremely low.
- The communication will be even at very low speeds difficult to make really reliable.
Rolf Kalbermatter  My Blog
(1,619 Views)
My bench test works 24/24 during weeks and i need a really reliable to have a good result.
Thanks for your answer.
(1,603 Views)
Since you need a reliable solution, you can use USB-232 and you need to use NI-VISA drivers to communicate.
BTW, DAQs do not come with any sort of communication protocol. Typically, DAQs contain Analog Input/Output, Digital Input/Output, Counters and signal conditioning.
Santhosh
Soliton Technologies
(1,597 Views)
To maximize reliability, I highly recommend a commercial grade externally powered USB hub for all of your USB connections.  I have had issues, particularly with laptops, where the built-in hubs do not supply enough power for the DAQ and/or RS-232 devices.  I am personally a fan of StarTech for these and USB-RS-232 adapters.
(1,569 Views)
