LabVIEW Tree Control - Setting Item symbol to 41 programmatically (Break or horizontal line)
Hi
How to set the Tree control Item Symbol to 41 programmatically?
Its possible to do it when the VI is not running.
Please see attached example.
/pmn
Message 1 of 8
(5,516 Views)
Hi PMN,
there are several methods available for Tree controls, one of them is called "Custom Item Symbols.Set Symbol": you can always add your own symbols and decide their index in the symbols array…
Message 2 of 8
(5,506 Views)
Hi GerdW
I know, but the Custom Item Symbol will only set the Item symbol in Column number 1 and not the horizontal line through ALL column
as shown at the picture on the VI.
The Symbol 41 will also clear all other text at the line. (like a new page brake)
Br Per
Message 3 of 8
(5,493 Views)
Hi PMN,
well, that's some special feature and is not "symbol 41".
With my LV2017 installation the line break is shown in a different position to indicate it is not a default "symbol"…
Message 4 of 8
(5,489 Views)
Hi GerdW
Ok but is it possible to set it programmatically?
Br Per
Message 5 of 8
(5,485 Views)
Hi PMN,
I haven't found a (programmatic) way to insert that linebreak in a tree so far. But I don't use treee controls often…
Message 6 of 8
(5,483 Views)
Accepted by topic author PMN1966
Set the value to -1.
I found it by manually inserting the break.  Then running the property node to tell me the value of the item symbol for that item.
Message 7 of 8
(5,462 Views)
Thanks RavensFan!
You are my hero!
(sorry for the late reply)
Br pmn
Message 8 of 8
(5,432 Views)
