LabVIEW Style Challenge - Error Wires
Steen,
As I said before, I'm open to reconsider the way I'm doing cleanups in LabVIEW. I'm not saying I will always wire error output of all close function but at least I will try to triple-consider if I'm missing a case.
But I will not change my way of doing TestStand cleanups, because they work really fine for me in my context (terminate, etc...). I agree with Sam about adding extra variables and preconditions : it sounds to me like over-engineering.
You can disagree, it's ok.
Maybe we can respectfully agree to disagree and stop the conversation here ?
Because I don't like the way it's going on.
I don't like your harsh tone either, sorry about that.
Anyway, it gives me a good reminder of why I'm not active on the NI forums.
Message 131 of 147
(3,596 Views)
@PragmaTest wrote:
I'm not saying I will always wire error output of all close function.
Nobody suggested you should. You didn’t catch my intent.
Yeah, me too. On the internet at all. Sometimes I wonder if people have lost the skill to read, with all the misunderstandings coming out of this.
We’re probably so used to preprocessed headlines that are designed to tell us what to feel, that it has become seemingly unnecessary to read all the words, from multiple posts in a fragmented thread. It’s sufficient to read a glimpse of the last couple of posts and form our own opinion of the other 90% we didn’t read, including a full characterization of the person who wrote it.
Death of complex and meaningful discussion.
Please keep on ignoring errors from your system cleanup code.
CLA, CTA, CLED & LabVIEW Champion
Message 132 of 147
(3,583 Views)
@PragmaTest wrote:
@crossrulz  a écrit :
@LLindenbauer wrote:
@SteenSchmidt wrote:
... 'TCP Close Connection' can output ca 15 different error codes, ...
I've been wondering about that - is there a way to look up the possible errors a given function might emit? That would be quite the help in figuring out how to handle them.
You can dig through the error codes and see what would make sense for a function.  Otherwise, see this idea: List every error code a function can give out!
Thanks for the link.
I took a look at it, in the comments it's explained that it's impossible to document the error codes outing of a function.
I don't find such an explanation in the link. Having worked with multiple APIs provided by hardware manufacturers, I found the level that the error output is documented to be generally correlated with how robust and pleasing to work with the API itself is.
On the matter of documenting, consider, for example, the Windows socket close function: https://learn.microsoft.com/en-us/windows/win32/api/winsock/nf-winsock-closesocket#return-value.
Consider also the fine-grained exception hierarchy present in python, where handling errors in a granular manner is considered an integral part of flow control.
Message 133 of 147
(3,574 Views)
It's in the comments below the idea. AQ said "
My Google skills have failed me. Can anyone find the post I wrote sometime last year about why this is impossible to do and link it here? I'm pretty sure I wrote up why this is problematic for API documentation in any programming language in epic detail either on ni.com or lavag.org, but I cannot find it and I don't want to type it again.
I know... it sounds like a cop out to say this is impossible to do, but it's true -- even Microsoft, with its batallion of tech writers, abandoned trying to document this for APIs. I wish I had the post that explained why."
Message 134 of 147
(3,570 Views)
This is my challenge,
Enrique
Message 135 of 147
(3,463 Views)
Enrique
I love that your notes implied code requirements that were not stated by the original poster!  Those code requirements MATTER to exactly how the code is written!
Better, get them nailed down before you waste time writing code.  Note: I have previously stated that I will not submit code for several reasons including the lack of use cases..
Now, as to your choice of where to branch the Error wire.
How do you expect to get a unique Error out of the Configuration file Read.vi String polymorphic instance?  The file itself text.  The reference is to a queue based object that stores STRINGS.
"Should be" isn't "Is" -Jay
Message 136 of 147
(3,448 Views)
The requirements I assumed by logic, what's the point of sending something to a queue or an event if what you are supposed to send doesn't exist, so if there is nothing to send but you had no error, the for loop would not do any iteration, I could have made a shift register for the error but I decided to explicitly put the wire in the order I consider important, I believe the code is a way to communicate ideas.
Message 137 of 147
(3,425 Views)
I threw together my best effort, and spitballing like that is kind of fun.
In reality, this challenge feels like "Here are 5 words, make them into a sentence" without specifying: What is the point of the sentence? What is the intent? What are you trying to convey? Who is your audience?
How do you judge what is correct? Correctness is situationally dependent... I would argue so is style...
Reminds me of this:
https://www.youtube.com/watch?v=aFwVf5a3pZM
Sam Taggart
CLA, CPI, CTD, LabVIEW Champion
DQMH Trusted Advisor
Read about my thoughts on Software Development at sasworkshops.com/blog
GCentral
Message 138 of 147
(3,414 Views)
Yea, incredible how 5 vis can be wired so diferently depending on the person in charge, it is really fun, there is not right or wrong if you don't have the full context, I remember one time I was doing the 'right thing' and that caused a huge issue on the production code, i deleted something I considered trash code, in the context of the vi, it was trash, for the full application it was fundamental, this reminds me the followingbug.pnghis is
Message 139 of 147
(3,399 Views)
Message 140 of 147
(3,349 Views)
