LabVIEW Simulation Interface Toolkit SIT server problem
I've installed Labview SIT and I followed the SIT tutorial like this:
http://zone.ni.com/wv/app/doc/p/id/wv-352
But when Matlab runs doesn't appear the message:
"Starting the SIT Server on port 6011SIT Server started"
but opening Simulink Library I find "Signal Probe block";
Looking in "Tool" menu of Labview I don't find the SIT manager.  Is something wrong with the SIT intallation ?
The versions are:
Matlab/Simulink 2008a
Labview 8.5
Labview SIT 3.0
(3,118 Views)
Hello escape 🙂
I believe that it has to do with compatibility between LV SIT, Labview and Matlab.. Below I am sending you an article where you can see the compatibility between each other.
http://digital.ni.com/public.nsf/allkb/D174674A91E5536286257428005C2426?OpenDocument
Antonios
(3,099 Views)
