LabVIEW Scripting: Property Node Class Name for IMAQdx?
I'm hoping that this is a trivial problem. I've really tried to comb through documentation, this forum, and fiddled with this quite a bit before asking and I just can't get this. It's the last barrier left in a pretty cool tool that I'm constructing and hope to share with the community.
Essentially, I'm trying to use LabVIEW Scripting to create an IMAQdx property node:
I'm so close! The property node below appears to be the way to accomplish this:
However, I need the proper "Property Node Class Name" and no, IMAQdx isn't it :).
So I have two questions:
  1. Does anyone know the Property Node Class Name that I need to reference?
  2. What is a general method for finding a Property Node Class Name?
Thanks in advance!
Josh
(2,351 Views)
Accepted by topic author jgoglio
1. User Defined Refnum:IMAQdx
2. Create the desired property node in a blank SubVI.  Open a Reference to that VI.  Index the first (only) element of the Nodes [] property of the Block Diagram.  Cast to Property, read PropClassName
(2,325 Views)
