LabVIEW Run Time Engine
Hi all,
I have an exe build in LabVIEW 2010 (32 bit SP1) and I am trying to use the application in another pc which has LabVIEW Run Time Engine. The pc is W7 PC which is 64 bit machine. I have a couple of questions here.
1. When we have the installer build should we use only 64 bit version of it or even 32 bit version of the runtime engine will work on a 64 bit machine?
2. If we install a 32 bit LV RTE in a 64 bit Windows machine, will it cause any performance issues?
Thanks in advance.
Bhalaji
(3,286 Views)
All you need is the LabVIEW 2010 (32 bit SP1) run time engine. The 64 bit version will not work with a 32 bit executable.
No.
(3,277 Views)
