LabVIEW Report Generation Word without installing any word processing software
thank you for your reply aputman and rolfk
It seems the xml is in the form of word xml/ word ml, which is quite different from the xml/xsl that web browsers use.
As, my final aim was to convert a template into pdf, I used an online editor to get the same template in HTML.
I then converted it to XHTML  and then to the XSL-FO.
The XSL-FO can then be converted to pdf using the Apache FOP.
So finally,
HTML -> XHTML -> XSL-FO -> PDF
Message 11 of 14
(1,703 Views)
Also, you can use Docx Toolkit from Viewpoint - it uses .NET, so you also don't have to install Word on the target machine...
Message 12 of 14
(1,693 Views)
 Thanks Kosist for your suggestion
Message 13 of 14
(1,668 Views)
Can you send me vi ?
It would be great favour..
Message 14 of 14
(1,319 Views)
