LabVIEW Real-Time Target setup: "PXE-E51: No DHCP or proxyDHCP offers were received"
 Hello all,
I've been trying to set up a LabVIEW Real-Time target on a PC solely dedicated to the purpose.
I've created a bootable USB drive following the steps in the following guide: https://knowledge.ni.com/KnowledgeArticleDetails?id=kA03q000000x4PhCAI&l=en-US .
After verifying and passing the system requirements with the use of the provided utility on the stick I tried to boot into safe mode.
Unfortunately this did not work. Nothing happened and I had to shut down the machine manually.
When I now restart the computer and try to enter the setup as before the machine shows its MAC address and tries to establish a link using DHCP. This fails and I get the following error: "PXE-E51: No DHCP or proxyDHCP offers were received" .
Why doesn't it boot from the USB drive as before so I can retry booting into safe mode and go on with the setup instructions?
How can I reset the behaviour to its default settings?
Has anyone had this problem before and knows how to fix it?
Many thanks in advance for any kind of help or even a pointer in the right direction....
Message 1 of 1
(2,465 Views)
