LabVIEW RT
Hi all,
Is it possible to use LabVIEW RT 5.1.2 with NI-DAQ 6.9
Thank you
Mike
(6,286 Views)
Yes it is. I have done it.
(6,285 Views)
I have a once more question.
Did you overwrited nidaq32.dll?
Thank you.
Mike
(6,285 Views)
I checked the NI-DAQ 6.9.2 driver and according to its readme-file it should work with the RT version you are currently using.  Not sure what you are referring to with your last question but it might be related to this.
Quote: Updating the RT Series PXI Controller for LabVIEW 5.1.2 Users
If you are using LabVIEW 5.1.2 with an RT Series PXI Controller, NI-DAQ 6.9 detects the Remote System Explorer if it is installed on your system and automatically updates the data acquisition files. After the NI-DAQ installation completes, follow these instructions to update the PXI controller:
1.            Launch Remote System Explorer.
2.            Select the PXI system to upgrade, then click Tools»Install/Upgrade Software to open the Install/Upgrade Software dialog box.
3.            Choose install.rts, in the ~Remote System Explorer\install\pxi directory, as the install image.
4.            Click Install.
5.            Verify the list of software to be installed, and click Proceed to continue with the installation.
6.            When the installation is complete, click Close, then click Yes when prompted to reboot the system.
Jimmie Adolph
Systems Engineering Manager, National Instruments Northern European Region
(4,909 Views)
