LabVIEW RT question
Does anyone know what directory the error log file rtlog.txt is stored on
the PXI flash? I believe that it is in C:\ni-rt\startup\temp however I
can't seem to get ftp access to this folder.
Also, assuming that I can get access to this file... Is there a lookup table
to help explain the errors in the log??
For example... the text below is part from the rtlog.txt error log file...
what is a code 8 or a code 18 error?
Thanks in advance for your help.
-Tom
System log started Wed May 28 01:45:27 1980
*** REGISTER DUMP FROM EXCEPTION HANDLER (code 18) ***
EAX = 0x00000000 EBX = 0x0020B544
ECX = 0x12F066A5 EDX = 0xFFFFFFFF
ESI = 0x00000000 EDI = 0x011E3B98
EBP = 0x005C3D34
CS = 0x0018 DS = 0x0020 ES = 0x0020
EIP = 0x003ae671
Call Stack:
Level 1 : Code pointer: 0x00179323 Stack Base: 0x001C4CC0
Level 2 : Code pointer: 0x00000001 Stack Base: 0x00000000
System log started Wed May 28 01:45:41 1980
------------------------- Serial Devices
nstalled --------------------------
COM1 - COM2 | PXI Controller Built-In Serial Interfaces
------------------------------- End of
ist ---------------------------------
System log started Tue Jun 03 00:26:30 1980
*** REGISTER DUMP FROM EXCEPTION HANDLER (code 😎 ***
EAX = 0x00000000 EBX = 0x01998054
ECX = 0x0000001D EDX = 0x00180E04
ESI = 0x004B69BC EDI = 0x00010000
EBP = 0x01903F10
EIP = 0x003d2fc7
Call Stack:
Level 1 : Code pointer: 0x0030AEF3 Stack Base: 0x01903F4C
Level 2 : Code pointer: 0x019FC9B5 Stack Base: 0x01998000
Level 3 : Code pointer: 0x003A0BB2 Stack Base: 0x00000000
System log started Sun Jun 08 03:25:58 1980
EAX = 0x00000000 EBX = 0x01994780
EBP = 0x01904F10
EIP = 0x003d2fc7
Call Stack:
Level 1 : Code pointer: 0x0030AEF3 Stack Base: 0x01904F4C
Level 2 : Code pointer: 0x019AA3A0 Stack Base: 0x01994000
System log started Sun Jun 08 03:26:12 1980
System log started Sun Jun 08 03:33:40 1980
(5,277 Views)
Never mind folks. I found the file. It is located in the c:\ni-rt\system\
folder and I have total access to it.
-Tom
"Tom Byers" wrote in message
news:3cbdaf88@newsgroups....
table
> -Tom
> EBP = 0x005C3D34
> EIP = 0x003ae671
> Call Stack:
> EBP = 0x01903F10
> EIP = 0x003d2fc7
> Call Stack:
> EBP = 0x01904F10
> EIP = 0x003d2fc7
> Call Stack:
(5,275 Views)
Actually don't totally never mind my first post. I still need to know what
the error codes mean.
news:3cbdc35e@newsgroups....
c:\ni-rt\system\
> -Tom
on
> table
file...
> > -Tom
> > EBP = 0x005C3D34
> > EIP = 0x003ae671
> > Call Stack:
> > EBP = 0x01903F10
> > EIP = 0x003d2fc7
> > Call Stack:
> > EBP = 0x01904F10
> > EIP = 0x003d2fc7
> > Call Stack:
(5,276 Views)
Tommy,
These error codes are only useful to National Instruments Technical Support. Actually, they are useful when Technical Support also has the VI which reproduces the error.
Is the problem reproducible?
Chad H
Applications Engineering
http://www.ni.com/ask
(5,276 Views)
