LabVIEW RT error message
To all:
I receive the following message when first starting my PXI system and
downloading a program to the embedded system. After running and downloading
additional programs I do not receive the message.
"Failed to load shared library c:\ni-rt\system\Motn_exe.dll on RT target
device"
It doesn't appear to cause any problems with the running of the program
however I am just a little concerned as to what is this related to.
-Tom
Thomas L. Byers
tomb@first-sys.com
http://www.first-sys.com
First Systems Corporation, Inc.
4 Chatham Court
Westerly, RI 02891
(401) 348-0542
(3,352 Views)
Thomas,
I believe that the problem is that you have NI-Motion software installed on the RT Series PXI controller. This really isn't a problem. You can check this by opening the Measurement and Automation Explorer, pressing F5, selecting your PXI controller from Remote Systems, and then selecting the Software tab (or Firmware) at the bottom of the screen. You may see NI-Motion listed as installed on the RT Engine but not the Host PC. If you want to reinstall the firmware without installing NI-Motion, right-click in the white space of the software (or firmware) window and select "Install software...". Check the pieces of software you want (even if they are already installed)and continue as directed. When asked if you want to uninstall previous versions, sa
y yes.
Chad H.
http://ni.com/ask
(3,352 Views)
