LabVIEW RT MAX Remote System Error
I am using multiple LabVIEW RT PXI Systems, and when I try and view the remote system tasks, as soon as I click on the task, I get the following error for all systems.
"LabVIEW: An exception occurred within the external code called by a call library function node.  This might have corrupted LabVIEWs memory.  Save any work to a new location and restart LabVIEW.   VI "AdvancedTiming.vi:1" was stopped at node " " at a call to "DAQmxAssistant_DAQmx Get IO Control Info.vi"
Any ideas would be greatly appreciated.  I've tried the usual reboot, open up the LabVIEW code.
(3,165 Views)
Dear ADL,
This error will normally occur when the parameters of some functions in (Call Library node)dll are not correctly initialized.
Check out ur dll again.
Post if still problem persists.
Mathan
(3,162 Views)
